Hi Guys..I`ve purchased a power commander V for my 2009 VV..The instructions show 2 wires that are connected to the stock ECU.I don`t seem to have these 2 wires coming out of the power commander V.I only have the wired harness to the Injector bodies & one wire which connects to the throttle sensor. Could anyone out there give me any info on this please..cheers guys..ride safe...
I'm guessing you got the 17-006 model without the ignition advance. Is that the case?
The one with the ignition advance ((17-003 )should also have wires going to both coils. The two wires from the ECU are the Crank position sensor wires, so the PCV can phase the compression stroke.
I went to Dynojet's site and looked at the install PDF for the 17-006 non ignition model, and it does show the ECU wire hookup.
You should call them and ask what the deal is.
The very first model that came out for the Voyager was the 17 – 005, I think it was.
I bought it when it first came out back in 09. Anyway it did not have the wires going to the ECU. I sold it a long time ago and got the 17 – 033(with ignition).
Can you tell us the model you got?
...Hi..I`ve got the 2009 model..Had it from new...got 12k on clock now.Fitted D&D exhaust along with the K&N air filter.I`m hoping the Powecommander will give it a little more umph...It appears I have the earlier Powercommander model..got it on american ebay at half the cost of new in UK...
No I mean what model number (or part number) of the PCV you have.
Have you got it installed yet?
...sorry.. thought you meant my voyager...The PCV is used..I got it off ebay..I hav`nt fitted it yet.There ar`nt any visible model description on thePCV..There is a bar code sticker on the rear but it has been partially covered by the velcro fastener..I`ve noticed that there are issues regarding the Ignition retard on the newer PCV owing to engine temp..will this also be an issue with this former version.I`m only looking for a small improvement..basically just to prevent my motor running to lean...thanks for your reply...
