1 - 3 of 3 Posts
So Ive wanted white walls for a long time but never pulled the trigger because of the price, and I wasnt sure I would like the look. Than I found These Port-o-wall white wall toppers at Mooneyes.
These are a white ribbon, that you install after the tire is on the rim. They get pinched into the bead and are held in place by air pressure.
They are not the easiest things to install nice and flat, but for $15 bucks a Piece I can get a real feel for how white walls look. One side went on flawlessly, but I had a little trouble getting the other side to lay flat. That was most likely an operator error more than a flaw with the product.
Two Kenda Kruz tires and one set of white wall toppers for less than a Metzler www tire.
Not sure if you posted a pic. But I would love to see some. Cuz that would be better then having to drop down to a 170.
1 - 3 of 3 Posts
