1 - 4 of 4 Posts
Pod Filters are on. (54mm)
Reed ports are blocked
Carburetor is re jeted (dynojet #140)
Crankcase tubing and filter are all set.
Need to synch the carbs, have a pretty good idea of what I am doing and trying to accomplish.
My question is, on the carburetor with the pod filters I understand that some ports need to be capped off. After synchronization are both vacuum lines capped off or just the Right side (facing front) ?
Is that the only one that needs to be capped or are there more?
1 - 4 of 4 Posts
