Discussion Starter · #1 ·
I rebuilt my petcock and it still leaked on reserve.Fed up I looked around to see if there was a replacement.Nobody knew of any.
This is also a very common problem on the Suzuki Savage.And their fix is a Yamamha Raptor 660 petcock.It's a manual valve with no vacuum. On/off/reserve.
I wanted to ride so I pulled one off of one of my Savages and tried it on the 800 and it works.
The only thing I can see visually is it might get a little less mileage in the on position and a little more on reserve.Seems like the Raptor on tube is just slightly taller.
This is one of those things that's a 50/50 shot on the rebuild. Some it works for and some it dont. Many have gone to a full manual petcock, just remember to turn it off when stopped for any length of time and then turn back on. This is something I would likely forget to do.
Nice to know it worked for you. My last bike had a manual petcock and my problem was always remembering to turn it back on, not so much off. I'd get to the end of the street and it'd start stumbling. Oops - glad I wasn't on the highway yet! :)
Discussion Starter · #4 ·
I'm used to it with the Suzukis and my Harley.I would have rather the rebuild would have worked.I've read on here about the K&L kits.Seems like not many are successful.Like Rick said 50/50 shot I guess.
I looked on here trying to find a replacement.Didn't have any luck.So I figured I would at least post this so there was an answer/option for replacing the original.
1995 Kawasaki Vulcan 800A
I got the Raptor petcock but I noticed a big difference in the size of hose barb from the stock to Raptor petcocks and carb. How did you get around this?
Super Moderator
Hi Whiskeymoto. This thread is over five years old. It is easy to miss the original posting date. Don’t know if you will get a response. Suggest starting a fresh post in the 800 Model Section so fellow 800 members can help out.
