1 - 4 of 4 Posts
Discussion Starter · #1 ·
I'm reattaching the alternator/ stator cover with a new Rick's paper gasket. Does anyone know if I should use a liquid gasket sealer like Permatex to treat both sides of the paper gasket or do I just install the gasket as it is?
I cant speak for your specific application but usually you'd use a gasket OR a sealer like permatex. Some times it helps assembly to put a few dabs of sealer on one side of a paper/rubber/cork gasket to keep it attached to one of the parts while you get the first few bolts in.
BOTM Winner, April 2015
No gasket sealer needed, the gasket itself will seal fine.
Discussion Starter · #4 ·
Thanks. I already installed the gasket without using a sealer. It holds perfectly.
1 - 4 of 4 Posts
