1 - 4 of 4 Posts
So, I released the pressure from my shocks since I just bought the bike and had no clue what kind of pressure was in there. Both shocks sprayed some oil out with the air. And it was a good bit of air, so I'm guessing one of the previous owners pumped the heck of of them.
I'm good with leaving them on 0psi till I get a pump, but should I worry about losing oil every time I release the air?
It's an 05 1500 classic, BTW.
I've got an 08 1500 Classic and the shocks have done that since day 1. Never questioned it and they've always worked well with 40 K on the clock. I wouldn't ride without air. I usually put 30 to 36 PSI with a manual pump that has a gauge. Here's a mod I installed. Air Shock Balance with Progressive AFB1 Kit
You really need some air in them, for the shocks to work proper.
Figure on 10% of the load you are carrying.......If you weigh 180 lbs. ,you need 18 lbs. of air.in the shock.
I'm just waiting for some auctions to end on eBay so I can buy a shock pump and get some air in them. I'm not doing any serious riding between now and then.
1 - 4 of 4 Posts
