1 - 8 of 8 Posts
The other day, I hit a patch of ice and dropped my 900 on the right side at slow speed. When I got it back up and started, the oil light was on. Rode about 3 miles and it died and would not restart. My buddy said it sounds like the battery is shot, so I replaced the battery. Now it starts fine, but the oil light is still on. Oil level looks good. I don't trust putting it on the road until I know it is fine. Any one have any suggestions on what would be causing the oil light?
Thanks,
Richard
If the engine was running when it went over the oil pump has lost its prime. Try 'burping' the oil filter to reprime the oil pump.
Loosen it just enough so the gasket isn't making contact..then start the engine..be prepared to immediately shut it off as it can make a giant mess fast.
Sent from my LM-Q710.FG using Tapatalk
Thanks...I had never heard of burping an oil filter....but I will store it in my sponge of a brain for future use. :)
2009 Vulcan 500
Try and rig up something where the oil shooting out all goes down..split an old can and have the slit pointing down for horizontal applications..on vertical applications..no slit..just a can with no top or bottom.
Some people run into trouble just changing the oil..they can't get the to pump suck up the oil .
1 - 8 of 8 Posts
