1 - 16 of 16 Posts
Hello everybody, I have a 2010 Vulcan 900 classic and I don't have an owners manual. I need some help on my oil change. What type and weight oil do you use. Also how much do do I need to buy. Oil filter brand and part number. Can I get these anywhere or dealer only?
Thanks in advance.....
welcome to the forum
Wal- mart is the place i get all of my oils got lots of Wal marts 10 miles from each other I use super tech 10-40 syntetic on all my vehicles including lawn mower, my local NAPA has good prices on oil filters and spark plugs
i
Welcome. Nice bike! Make sure you use motorcycle specific oil. I use a Kawasaki oil filter. Here's the oil that I use:
Filters for your bike:
Some quick google searching turned up this:
Oil Filter:
Bosch 3300
K&N 303
mobil M1 108
Purolator PL 14612
Supertech (Wal-Mart) ST6607
I use the mobil M108 and castrol 10 w 40. Have also used royal purple as well as .
For Oil: Use Motorcycle specific. Do a search, many options.
If you need specific assistance with the oil change, do a search or ask away!
I use Kawasaki 10w-40 full synthetic and a Kawasaki filter on mine. Amsoil, Mobil 1 Racing 4T and other JASO MA full synthetic oils are fine also. Others will say any JASO MA oil, but I only use full synthetic in any of my internal combustion engines. It takes just short of four quarts with the filter change.
Walmart Shell Rotella 5w40 full synthetic JASO MA rated for $21.97 for 4 quarts.
K&N 303 from Amazon because I like the 17mm nut on the end to torque the filter to exactly the right tightness with my Harbor freight torque wrench. :)
Discussion Starter #10
Wow, thanks everybody for the quick replies. Great information. I'm so glad there is a place on the net to get some help when you need it.
I will be changing the oil in the next couple days.
...Also, make sure that you recover the drain plug washer when draining the oil ( Kawasaki recommends replacing it). Sometimes it ends up in the waste oil. It's also a good idea to torque the drain plug to factory specs when reinstalling; don't want to over tighten and strip anything.
I don't have a shop manual yet. Whats the torque on the filter and drain plug?
Be gentle! 15 ft-lbs is not much. And remember the washer on the plug...do not ry and tighten the plug without it.
Tighten the drain plugs.
Torque - Engine Oil Drain Plug: 20 N·m (2.0 kgf·m, 15 ft·lb)
The drain plug is 15 FT LB's and the Filter is 13 FT LB's.
Whoever did the oil on my bike before I bought it didn't seem to think so. That thing took a trip to Home Depot for a huge set of pliers just to get it off, and I nearly destroyed the filter in the process.
Just thought of another tip :): During the time that you’re draining the oil, pre-fill your new filter with new oil and let it soak in before installation. That way critical parts will get oil faster when you start it up.
1 - 16 of 16 Posts
