Has anyone posted about the voltage regulator being in the way of the oil filter?
I believe it's placement is based on cooling. They will run hot.Since the voltage regulator crowded the new Drifter fender I put on the wife's 900, I went ahead and re-located it to the left side of the bike with the purchase of 1 longer bolt and a spacer. Problem solved forever. I don't understand why Kaw put it where they did, makes absolutely no sense. Pics to follow.
They put it there due to heat, as others have mentioned. Other Kawasaki Vulcan models (the 750, specifically) have had tremendous issues with overheating reg/rect units causing failures, killing batteries; even catching fire. The Vulcan 900 and others now have the Reg/Rect located in the front of the bike where it gets plenty of cooling airflow.Since the voltage regulator crowded the new Drifter fender I put on the wife's 900, I went ahead and re-located it to the left side of the bike with the purchase of 1 longer bolt and a spacer. Problem solved forever. I don't understand why Kaw put it where they did, makes absolutely no sense. Pics to follow.
Do you have a meter with a temp probe? Or better yet an IR or laser temp gun? One thing you might try is to go for a ride (noting what accessories are on, lights, brights or not, etc., to keep things consistent)., read the temp in several situations and note them at your current mount, and then try and re-create those mounted in the stock location and see if it's operating warmer.Guess I'll just take the cover off, since it's not in danger of being struck by road debris, may even make an air deflector to force air onto it. That should provide sufficient air flow.
Doesn't even need to be 4 bolts! If I recall correctly, even the service manual just says to remove the one side and turn the reg/rect unit to expose the oil filter. Just takes a couple seconds. I don't take it off, I just swivel it out of the way by taking off the cover and then the bolt on one side.Good idea. I'd hate to hear you have a bunch of problems just because of the inconvienence of 4 bolts.
