1 - 2 of 2 Posts
Discussion Starter · #1 ·
For those interested in Installing saddlebags on a Vulcan S. Its really not that tricky, and many here I'm sure are much more mechanically inclined than I am. But the bike was in for some routine service and I took the opportunity to have them just throw on a pair if Viking saddlebags that were supposedly bike specific. They declined saying that the OEM backrest made it impossible. Really not the response a shop should give. I wish they just said they didn't want to
Anyway, the OEM backrest made it only a tiny bit trickier. I am sure that the provided brackets could have partly worked but its interesting the the holes in the brackets were close but did not align with the holes in the bike. I am assuming that the brackets were SAE but I didnt take the time to measure them - Instead I purchased a pair of Kawi OEM saddlebag brackets. Made the job more expensive but its a sturdier install. These brakets mount inboard of the backrest bracket and they come with bushings welded in place to replace the bushings on the backrest.
Once installed, there are 4 grommeted hole in the bags, in theory to give you some flexibity fore and aft. Again as it turned out the alignment of the holes is close but off by 1/4 inch or so, necssitated over drilling one of the holes. From there simply marking and drilling a third lower hole was straightforward.
In the end thu look good, fit well, clear the rear pegs - they dont hold much but thats a different story
Tire Wheel Plant Vehicle Fuel tank
Fuel tank Tire Plant Vehicle Wheel
Tire Wheel Plant Vehicle Automotive fuel system
Thanks for the info! We installed Viking bags on my wife's KVS (with the backrest) and had a similar experience. I'm honestly not a fan of the Viking installation brackets. The bags are nice, though
1 - 2 of 2 Posts
