1 - 5 of 5 Posts
Hi,
Am Ahmad Jan from Saudi Arabia, i have a 11" Vaquero Europ specs (Voyager Custom) which had the Oxygen Sensor, i installed a Cobra slip-on mufflers with billet scalloped tips and a K&N air filter.
I need to install a fuel managment device, do you recommend a one for me?
I need also to change my sparkling plugs, i have search the net and found (
SET of 2 PERFORMANCE SPARK PLUG Kawasaki VN 1700 Vulcan Voyager all * GTZOXC2BR14ZCYU134
[ame]http://www.amazon.com/dp/B008M6YFLE/ref=cm_sw_r_an_am_ap_am_us?ie=UTF8[/ame] )
Do any one have tried it, do you recommend .... and how does it effect on the performence of the bike?
Thank you
I can not speak to the spark plugs but I know most on here will recommend the Power Command V. There are multiple on here that have installed it and love it. There are also plenty who have made fuel maps for it for the different set ups.
If your Vaquero is like what we get here in the States the Vaquero comes with projected Irridium tipped plgs from the factory and have a lifespan of over 40,000 miles. No need to change them any sooner.
Due to the projected tip along with the other advantages in the design of the center and ground electrodes you will not find a better plug.
RACNRAY
Thank you guys .... my Vaq have an Oxygen Sensor (Europ Specs) and i made some modefication on my cobra slip-ons to install the sensor and it works ....
My question is which model of the power commander V?? .... or give me the direct link to the part on Amazon.
I installed the PC5 17-033 that's W/ignition but you will have a few more wires to hook up. The other one is the PC5 17-006 just fuel and I believe that just plugs into the throttle body and your done. Than you'll need to download a map to the PC5 that best suits your modifications you've done to the bike, You can get a map from the power commander site or I'm sure one of these helpful fellas with send one to you that you can try.
1 - 5 of 5 Posts
