1 - 5 of 5 Posts
Hi 900 owners. I'm looking to customize my 1500 88 and am thinking about using the curved chrome rear fender supports from a 900. Can someone tell me the center to center distance between the mounting holes? Any help is appreciated. Thanks.
Jeff
Thanks Steve. Is that left side to right side? What is the bolt to bolt distance? For example, the three bolts on mine are 14mm and 9mm from each other going front to back.
OK, ignore my previous post. Of course my bolts are not 9 and 14 mm apart that's cm (230mm total) and so it seems the 900 supports are going to be perfect. Thanks again Steve.
Now I'm not sure I measured what you wanted. I measured the bolts that the passenger backrest uses.
1 - 5 of 5 Posts
