1 - 5 of 5 Posts
Discussion Starter · #1 ·
I'm in the process of swapping out my rear turnsignals for Kuryakyn dual circuit run/turn set-up
that has three ( 3 ) wires compared to the two ( 2 ) wire OEM set-up .
Would I hook up the run wire to the RED wire going into the taillight ?
Also is it a safe bet that if I wanted to run a new license plate light
I can cut the exsisting 2 lines and re-direct them to the new two wires.
yes.......(bk/y is ground)
yes
Discussion Starter · #5 ·
Well... all went well. Not perfect. I had to dismantle everything once before I got it right.
I did it all in one shot.
Plate relocator - Barons turnsignal bracket - Kuryakan duel circuit turnsignals - led license plate holder.
Turned the key and all worked with no sparks or fire.:)
Knocked another project off the list.
Thanks to RRKR for confirming the wire set-up.
1 - 5 of 5 Posts
