1 - 9 of 9 Posts
Discussion Starter · #1 ·
I HAVE A 2000 VULCAN N1 1500 CLASSIC FI, I just changed the clutch spring with the MEAN STREAK spring. After I got it put back together I pulled the clutch lever and NOTHING!!! No pressure on the lever what so ever. I tore it back down and everything was ok, so I put it back together again and still NO PRESSURE on the clutch lever!!! what do I do now? Thanks:confused::confused:
Other then that, ya got me!
Don't forget the tiny return hole in the resovior. If it's plugged, it'll do exactly as you're describing. A sewing needle does a good job of cleaning it out.
Discussion Starter · #7 ·
I want to say a big thank you to you guys for your help!! I cleaned the reservoir and the tiny hole n bled the lines. I have a cluth again!! Once more thank you!! BIG HACK
I hate it when things like this make you doubt yourself.....
1 - 9 of 9 Posts
