Motorcycle lift for Vaquero
3.4K views 4 replies 5 participants last post by  UTScout
#1 ·
I am having trouble cleaning the lower left side of the motorcycle, especially the exhaust pipe because of the lean angle on the kick stand. Is there a bolt on stand to buy for this machine or do I need to purchase a lift to do maintenance like oil changes and cleaning, etc.
What about tire changes on the road if a flat happens?
new to the cruiser style machines, coming from adv bikes.
#2 ·
The Vaquero has a nice flat bottom so any motorcycle lift should work fine. I bought mine from Harbor Freight, but my son got his there and I don't like the way the valve works on it. If you have a set of auto ramps (I like the plastic ones), you can use one to tip the bike over at a steeper angle and from either side to help accessing the pipes. I also pull the bags off when I'm cleaning her. I don't know of anything you can carry with you to lift the bike for wheel removal. I tire plug kit and a CO2 unit to add air is about the best I've seen for roadside flats.
This is the style of jack I use:
#3 ·
I have the same lift.
It comes in handy quite a bit. I also use it to lift my mower when I need to sharpen the blades
The saddle on these lifts are quite short now. I bought some C channel and made my own that are about 5" longer.
The stock saddle only stuck out a half inch on both sides on my Nomad and I got paranoid every time I jacked it up .
Now with the longer saddle I think its a lot more secure
#4 ·
I used the same lift when I put my lowering kit on.
just for reference I also used a front wheel chock from HF and I used 2x 3-ton jack stands under the rear crash/support bars to keep the bike elevated. the jack stands were a fantastic use case as I was able to perform all work with the bike stable
