1 - 18 of 18 Posts
So I got this floor jack yesterday for black friday http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200326249_200326249?cm_sp=Xsells-_-Manual-_-Product Page
Got it for 69 bucks so I can't expect alot out of it. But normally it goes for like $110.
So the problem I am having with this lift is that doesn't seem like the platform legs are long enough to make the width of the bike frame or they are really, really close. And the space between the platforms are not wide enough to fit and not hit anything. Either it is hitting the engine oil pan or it is going to hit the suspension knuckle (which still has all 3 zerts, shockingly enough). So is this just maybe this jack in particular or is this just a problem with this bike?
You may need some "help" in the form of some 2x4 pieces to use as spacers. I've had my 900 lifted using a PitBull lift and the mechanic used spacers with it. I consider the PitBull the Cadillac of lifts even though they're pricey. If your lift has eyelets for tying down your bike, I recommend you use them and strap it down just to be sure.
I bought a Larin floorjack and had the same problem (also got it on sale for $69). After looking at a number of different jacks and they all had about the same width I figured I would just modify the one I bought to make it work. The struts that catch the bottom of the frame need to be at least ~13-3/4", most of the jacks I looked at were about ~13" wide. The front is a little narrower than the back of the frame, I actually had to modify my design because I only measured width of frame in the front.
I went to a little more trouble than using 2x4's, I machined some aluminum blocks to give me the extra length and offset to clear the oil pan. I had to remove the tie down eyelets for the extensions, but I machined in a lip at the end of the block I fabricated so the frame couldn't easily slip off the end of the strut.
I think you may be able to find a jack that has the width but you will still have to have some spacers to clear the oil pan because it sticks down lower than the frame. I found one that had the right width but cost ~$350, so that was not an option for me.
I know it's pricey but just pointing it out...
Adaptor
That adapter is actually a Larin product. I doubt it would work on our bike and the jack I have. Cuz this jack doesn't go down as far as the Larin does. Even when I got it to work (barely) after I lowered the bike I couldn't get it down all the way enough to remove the jack, I had to jockey it around a bit.
But the link that MN-Nomad provided, the price for the jack with adaptor aint bad, $169. But you have to pay for shippin which is like 11 bucks. But I like that it has out riggers on the jack. Seems pretty stable.
I found that ONCYCLES.com has this jack with the adaptor for $160 and free shipping. http://www.oncycles.com/catalog.asp?r=1&pn=MCS00255 I think I will be returning this piece of crap and getting that one.
rs900c did you get yours at blaine farm and fleet? Other then the fitment is it a decent jack?
This one (Torin) is kinda cheap, the locking arms are weird they don't lock on both sides at the same time, cuz they seemed to be tweaked. And the jack itself doen't sit flat on the floor it rocks. This is something people on the reviews mentioned.
jimbo i thought about the 2x4 but not sure it would work. It does have eyelets and I bought straps.
I would like to see some pics of how you guys are doing the spacers and where you are placing things.
Yes, I got this from Farm & Fleet. It's decent, not top of the line, but I wouldn't say it's a piece of #hit either. The components seem to be beefy enough, their fixturing before welding and on some punched holes weren't that great. Things could have been kept more parallel and square. All of the welds look ok. It seems to work fine. It's worth the $69+ I spent.
I got mine from Sears, it's a Craftsman jack. The length of the arms are just barely long enough for my 900 and my 750 Spirit. The width might be better, but careful placement on both works for me. As far as sticking a 2x4 in there, no way... there's barely enough clearance as it is. Mind you, i have lowered both my bikes by about 2", so maybe that's the reason. Sure makes maintenance and oil changes a lot easier; don't know what i'd do without it. It comes with two tie-down straps.
http://www.sears.com/shc/s/p_10153_12605_00950190000P
It looks likes the Craftsman and the Larin have a foot lever to lower the jack. This one I have doesn't, I had to reach all the way to the bottom to twist the lever and try to hold the bike up at the same time.
Jace, the foot lever on my Larin is only for raising. There is a square headed valve stem at the base of the jack that needs to be opened in order to lower jack. The Larin comes with a handle with square cutout that you have to place over valve stem so you don't have to reach all the way under to lower but it's still a bit akward to use.
Discussion Starter #11
Yeah the one at oncycles.com must be a different model.
The Craftsman jack has two foot pedals. One to raise, one to lower. They both work fine for me. Varying pressure on the lowering pedal allows you to adjust the dropping speed. I like it.
Discussion Starter #13
Thats what I wan't, how does it do as far as the brackets lining up to the frame of the bike. These other ones needed major mods. At least the one comes with a bracket that seem to allow one to place and lift where you want to lift at.
How does the craftsman deal with that?
I'm not sure what you mean by "brackets". Do you mean the arms that actually touch the frame and lift the bike? If so, like i said in an earlier post, with careful placement, it works for me. They just barely stick out on either side of the frame lengthwise. As far as the width, it's not perfect, but it works. I'm happy with it.
If you decide to get one, watch for sales. When i put the original post up with the link, the cost was about $61, i just checked again and it was $120. I think i paid about $80.
Discussion Starter #15
This is the bracket I was referring to.
The Craftsman doesn't come with that, and i dont' think there would be enough clearance to add it onto the jack (for my bikes anyway).
Discussion Starter #17
Yeah I think that adapter is for their product only. I returned that jack today. Hopefully I can get that other one before spring. Next oil change I'll just have to trust my wife to steady the bike on my car jack.
I'm looking at gettting the Craftsman one to since winter is coming up and its going to be taking up space in my garage.
1 - 18 of 18 Posts
