1 - 3 of 3 Posts
I’m looking to swap motor, wiring harness and tins from an 04 Nomad 1500 fi to a 98 Classic 1500 ci frame.
Is it “plug and play” or will there be modifications that need to be made?
Thanks in advance!!
BOTM Winner, October 2014
I’m going to assume from a nuts and bolts perspective, it’s all there, and will swap. I’ve put a lot of parts from Nomads on my Classic. The Nomad left engine cover has a completely different generator system than the Classic, but with you transferring the harness and all, you should be good. I don’t suspect there will be drive shaft fitment issues. The nomad dual exhaust depends on the bag brackets, but bolting on a Classic one side slash cut or similar is compatible with the heads. I’m thinking the connectors for the lights will be different on your harness, but there are a lot of solutions for that. I suspect if you aren’t transferring the bar controls, you may have electrical connector differences there too, not because it’s from a Nomad as much as the 6 years of difference.
1 - 3 of 3 Posts
