1 - 7 of 7 Posts
Has anyone had a minor coolant drip from under the engine on a 900 Classic? It is the occasionable drip. I have heard that it is common issue with Vulcans.
I had a coolant hose clamp under the gas tank need to be tightened but never a coolant drip under the engine.Have you checked the coolant reservoir tank on the lower left side of the bike?
No,did not need to remove the tank.Check the hose clamps using a flashlight to see better.You should see a crusty buildup if any have been seeping.
Hose clamps are a fairly common item on these 900's need tightening, as others have pointed out.
In my experience though, one should use a flashlight like Bandit said and check all over. Wind (which gets swirled around and might not be going the way you think) vibrations, etc., sling that stuff everywhere. Check things like the area around the filler cap for evidence of coolant seepage, all hose clamps, etc.
As others have said check your hose clamps under the tank - but use a socket you will never get em tight enough with a screwdriver.
I will chime in on the hose clamps also. Most of mine were leaking. Tried to tighten, but still had a small leaks. Finally, I just replaced them with some from the auto parts house. Haven't leaked since in 5 years.
1 - 7 of 7 Posts
