1 - 5 of 5 Posts
I've had no oil issues before this. But, I just changed my clutch. The bike is back together. I refilled the coolant and the oil with new. I started the bike to run all the new fluids through. I was watching the oil level window to make sure the level is right. The oil is now a milky white.
Any idea what could happen during the clutch replacement that could cause oil and coolant to mix this way?
Air and condensation can make the oil look milky, not sure how long you let it sit after shutting it to see if it clears up.
I filled both the coolant and the oil then started the bike right away. I didn't let it sit at all after that. I checked the level in the window and noticed the oil was white.
Super Moderator
Do not run this bike. If the oil mixed with coolant after the clutch install, time to retrace your steps. I hate to do things twice but sometimes it happens. Recheck the O ring seals on the coolant pipe for proper installation. They need to be lubed with soapy water so they don’t twist when installed. Also, they have a tapered side that must face the engine. Do not know if you have a service manual, so here is a link.
1 - 5 of 5 Posts
