1 - 2 of 2 Posts
Discussion Starter · #1 ·
Hey! I dont know if this is normal but when I turn on the ignition the brown wire has current, but when I turn the ignition/light switch to the second notch where the lights should come on the current from brown wire disappears.
Is it normal?
Not sure what brown wire you're referring to, but when turning on the ignition switch, the headlight should not come on until after you release the starter button (regardless of whether the motor actually starts or not).
1 - 2 of 2 Posts
