1 - 3 of 3 Posts
I purchased the Luverne Kawasaki Lowering Links 3 weeks ago and installed them myself. The install wasn’t an issue other than being one thick washer short, something the local Home Depot hardware dept. was able to solve. However there was an issue with my saddle bag brackets. With the Nomad the brackets need to be sent to Rick’s shop to be modified do to the angle change of the rear shocks. The mounting holes didn’t line up as they should have and I had to use clamps and pry bars to get them where they needed to be in order to insert the mounting bolts and secure them. Definitely a concern and a bit frustrating as getting the brackets back on took longer than it should have.
Pros and Cons.
Pro: After putting over 500 mile on with the lowering links I do like the ride, handling of the bike and most importantly being able to put my feet flat on the ground when at a stop. I’ve ridden by myself, with the wife and loaded down for a trip to the beach and no problems with bottoming out or with handling.
Cons: 1) As stated above, the alignment issue with the saddlebag brackets. I did have a conversation with Rick and Mike about my trouble getting the brackets on and made some suggestions. 2) The overall cost. For me the cost was something I had to struggle with. With the Nomad not only do you have the cost of the lowering links but you also have the cost of modifying the saddlebag brackets and shipping both ways. But, after having the bike for over 3 years and dealing with the problem of not being able to sit at a stop flat footed, I opted to bite the bullet and accepted the cost.
All in all, in the long run I’m satisfied. Barring any unforeseen circumstances in the future I think I’m going to look back on this purchase as a good one. Hope this helps anyone out there that has been on the fence as to whether to take the plunge or not.
BOTM Winner, February 2016
I just had the shop put these on my Vaquero. Luckily its just a straight bolt on, no modifications needed. I like it so far.
I like them. It seems crazy but the ride even seems better.:grin2:
1 - 3 of 3 Posts
