1 - 20 of 24 Posts
I was thinking about putting on some windshield lowers to block out some of the updraft from below the windshield, does anyone have them and what is your opinion on how well they work. Where can I find a deal, Ebay is the best ive seen at 116.oo with free shipping so any input would be great. If anyone has any pics of them it would be awesome, thanks.
Windshield Lowers
I have some on my 1600. Would like to get some for the winter for the V2K also. Will post pick of 1600 tomorrow. Maybe some hand shields also, hate these thick gloves on the grips.
Those prices that optomatt's site had were good prices, but I've tried lowers on my '06 and it did virtually nothing to stop the updraft. I have heard that tilting your stock windshield back to match the angle of the forks will do wonders to stop the "UP YER NOSE" wind problem. I am going to try it very soon.
I put on the ones that go with my switchblade windshield. They are the chrome ones from cruisercusoms.com or something like that. They are awesome. Cut down the wind and helmet buffeting to almost nil.
Nate
Night and Day difference. Do it. One of the best things I did to mine.
Don't know why Kawasaki has it at the wrong angle to begin with.
Didn't they ride the thing after designing the windshield?
Put it at the lowest position and change the slot to be L shaped so that it tilts back and you're done. You'll like.
I ended up buying the Kawasaki OEM lowers from ebay for a good price. The other ones dont look as good in my opinion. Memphis shades has a pair for cheaper but you have to buy brackets and shields seperatly and with shipping almost comes out to as much as the Kawi oem ones which are much nicer. Anyway I heard by tilting the windshield to the angle of the fork does wonders but exactly how do you do that. I dont have anything to really cut the metal so how is it done?:confused:
Sounds like this Saturday's project to me......thanks for the 411!!
Die grinder and a carbide cutting tool. Every motorcycle owner needs at least one of those :D
Discussion Starter #10
can you use a dremmel toool or something like that, just wondering what i can buy that is not too expensive and will work to cut the L slot
I will add that I put on national cycle chrome lowers and it solved a really bad buffeting problem I had. I found the V2K to be a lot worse for this slipstream of air...but these lowers stopped the problem for me.
Annie
Discussion Starter #13
So the adventure began. I went to Sears and bought a dremmel tool and began the mod of changing the angle of the windshield. I took off the shield and had to take off a stereo which I installed. I went to my work bench and started. First I needed to figure out which head would do the cutting so I used a cutting tool which came with the dremmel. Took a while to cut but did the job fine. I didnt cut a drastic L shape but kept it at about half inch to 3/4 inch (L shape) Then I reinstalled the shield. Make sure when you cut that you make it wide enough for the bolts, had to go back and make wider. On the test ride, these are my results= Huge diffrence, almost no buffeting. I lowerd shield all the way and angled shield only 3/4 inch closer to me and Wow, it does make a huge diffrence. Thanks guys for the info and giving me the push to do it, Im very glad I did.
Toldja! :D
Glad you like. I did mine about 1 inch. 1 inch at the bracket makes almost 2 inches at the top of the shield.
Did you happen to have taken "BEFORE" and "AFTER" pictures??
Here are a couple "after" shots of the mod itself.
Also is a shot of me on the bike in the smoky's. You can see the angle of the windshield compared to the stock location. Basically matches the angle of the forks. Much better.
I think it looks better too.
Discussion Starter #17
I didnt take before and after but my cut is just like the ones in those photos for the exception that he went a little further than mine. I cut about 3/4 of an inch. I will probably cut a little more but for now its almost exactly like those pics and works great. Highly recommended mod. Easy to do, plus i still have my lowers comming in the mail so that should help improve wind and buffeting as well.
windshield and lowers
I dropped my Memphis Shades back to match the fork angle and added a set of chrome lowers for a Harley Heritage Softtail. I had to put the lowers on the opposite sides to get the slot in them to go around my crash bars, but they are fantastic at stopping the updraft. I used a carbide milling bit in my RotoZip (same as Dremel) to modify the slots in the mounts.:cool:
Lower shields
I used mine for a winter, at least, for the 2 or 3 months we get one here in south central texas. Still got a lot of wind up the leg. Took them off beginning of this summer, big reduction in up draft. I believe the lowers pushed more air on the road that then came back up my pants. Won't use 'em this year. Hand shields worked great.
1 - 20 of 24 Posts
