Poncho,
Is that all I need? What about the shock alternative (other than $$$)?
The two inch drop links aren't just straight brackets. If you look at the picture (of the baron's) that poncho did, you can see they have an angle cut into them.
The angle allows them to sit flush on the swing arm mount point.
I agree with the looks. That big space really looks bad.
I had the 2 inch drop kit installed for several years... you can see the difference in the pics below.
Picture one is back around 2008 or 2009. Stock tires, rims, no drop kit.
Picture two is with stock tires and rims, but WITH the 2-inch drop kit.
Picture three is WITH the 2-inch drop kit, but with rims that are +2 inches and tires that are low profile (bigger rims, smaller tires = same over all size)
Anyways, you can see it really helps the looks.
I DID however, take it off the 2-inch drop kit about 3 months ago. I installed the Progressive 465 with the 1-inch drop and the BAK.
I realized I don't have a picture of it.. most odd. I love taking pictures of the bike
It does of course, now sit an inch higher (down 1 instead of down 2). Maybe when this tire needs to be changed, I'll increase the tire size a bit.. or maybe even replace the +2 rim with a +3 rim. THAT would look sweet.
