1 - 9 of 9 Posts
I did a search on this already and couldn't find exactly what i was looking for. anyways, i want to put the 200 series metzler on the rear, along with lowering and the scootworks pulleys. 2 questions. will all this work together? and which pulley is everyone using, or could i use both with this setup? sorry for the newb questions but the search function didn't answer these questions.
I just put on the 200 Metz 880 this week, and it fits fine as my bike is stock in every other way as far as no pulleys or lowering.
I was told the rear 200 will NOT fit with an aftermarket pulley. Anyone else care to confirm this?
I've heard that, without mods, the 200 Metz will not work with the front pulley, as it pulls the rear tire forward a bit. It should work with a rear pulley upgrade, as that will allow it to slide back a bit.
i dont know about the pully but i know the 200 works with a lowering kit. i have the custom with a 1" drop and the metzler 200 on the back. ive put on about 200 miles on it so far and absoluty no bottoming out. i do not have either of the pullies on it so i dont know about that part of it. good luck
alright i rather lower it and put overdrive pulleys oncause im on the highway more often. which pulley do i go with, or can i go with both?
I just picked up a Avon 200 on a Custom 900 stock wheel from LitlDeuce for my 900 Classic because on the Custom, which I understand was lowered, caused the bike to bottom out when riding two up. Not sure if he has the Scootworks pulley on the bike or not.....
I would rethink going with both pulleys. Just the front pulley is a huge improvement, but both would make it strictly a slab cruiser with low end power virtually gone. I think you could use the rear pulley and that tire w/o the front pulley installed. Can anyone back me up on this?
I think you are right. From what I understand increasing the tire size (width and height) does the same thing as changing the pulley.
The effect of tire diameter can be calculated and compared with ratio changes from pulleys. I really didn't notice a change (except speedo was then near perfect) when I installed my Avon at 300 miles the Lop got a hole. The 900 has plenty of torque so it would take a drastic final drive ratio change (like changing both pulleys) before you would notice. There's plenty of room for a rear pulley w/Avon.
1 - 9 of 9 Posts
