1 - 8 of 8 Posts
Having some issues with choke and keeping motor running without choke wide open. Going to clean carbs, but should I do anything else?
Get a can of seafoam. Follow directions on the back and dump some into your fuel tank. Once it gets your system clean, use it on a regular basis. You will be glad you did.
Thanks, I was also thinking the issue might be with jetting and back pressure. I have cobra 2" drag pipes. I will have that looked at as well.
1 - 8 of 8 Posts
