1 - 7 of 7 Posts
I installed duel circiut rear turnsignals ( no load equalizer )
and all worked well.
I then installed duel circuit front turnsignals ( no load equalizer again )
and when I turn the signal on ALL FOUR turnsignals flash in unison.
Is it the load equalizer that I might need to tie in on either the front and or the rear to rectify this challenge :confused:
UPDATE
I went back and installed the load equalizers on both the front and rear.
Now the left side flashes ok - But the right when activated causes all 4 to flash.
UPDATE ( 2 )Thanks to Bob I now know what I need to get.
A Dioto wire
I just wired up some front mirrors with the signal/running light in the stalk and made pig tails off the factory connections in the front light housing and everything was good. Each mirror has five LED's in it, works great.
Ya but do you have the led's in the rear too ?
I had only done the rear and all worked ok until I added the front as well.
Thats when I heard about the diodo that I needed.
I took on to much at once not to know all the know how.
But I got some help from the forum and I pick-up the diodo tomorrow.
Can anyone confirm I got the correct wires here to attach the Diodo to :confused:
I come up with the GREY and GREEN.
Would this also be the way to hook up this diodo :confused:
Nope, standard bulbs out back BUT...the reason I posted that was when I was wiring up I tried to get as close to the switch as possible and run less unsightly wire. When I buttoned everything up and hit the switch and it blinked I was as proud as a peacock. Then when I cancelled it, it was still flashing. So I took everything to the factory ends and just ran the wire along the handlebar with the rest. I did get 3/8 shrink tubing and covered the wire so it would look better and give some protection.
Sorry I can't be of any help with the meter. Do you have a wiring diagram to help you?
Here is the wiring diagram I pulled showing the Indicator and the colours
it states they are. I'm pretty sure that I'm right.
Just want to play it safe and get confirmation before cutting into the
main wiring harness.
Anyone ????
Got it done. I didn't splice where I showed in the diagram below.
Spliced the other side ( meter side ) much better.
All worked perfectly.
No more lollypop turnsignals. Gone bye-bye
1 - 7 of 7 Posts
