1 - 3 of 3 Posts
I bought a Street Magic LED Isolator, which is supposed to be installed on the wires to the TS indicator bulb. When I take the instrument cluster out, however, the sub-assembly containing the dash indicator bulbs plug into the cluster via a multi-wire connector, all but one of which are white.
Does anyone know how to easily wire one of these doodads up? Thanks!
Turn Signal Indicator
The S/M shows a grey wire (right) and green wire (left) output from handlebar switch leading into the 20 pin connector to the speedo unit housing the t/s indicator lamp. Hope this helps.
1 - 3 of 3 Posts
