1 - 3 of 3 Posts
Has anybody tried to replace their H7 with an LED? I have tried two and the base on both was to big. The wire clamp that holds the light in place will not fasten on either bulb. Would like an LED if possible.
Discussion Starter #2
Went to Cycle Gear and they figured out my problem. The silver piece that fits around the bulb and holds it in place with the d slot comes apart. Take a screwdriver and slowey pry it from the bottom of the base and you have an H7 bulb. Place the silver ring around the new bulb and press it into place !!! As good as new.
Thanks for the heads up on that little tip!
1 - 3 of 3 Posts
