I have a VN750, my relay is located next to my battery, that’s the only turn signal relay on the bike. What is the part number on your stock relay? There is an electronic flasher equivalent for each standard type. You should be able to cross reference and find it.Hello Mmart do you remember where this plugs into? The only relay I have found is a two pin in front of the battery
And to add to this thread, I have changed all the lighting on this bike to LED except for the gauges and indicators on the dash. The difference in the headlight over stock was just flat out ridiculous. I also have amber bulbs behind amber lenses for my flashers and they’re far brighter than stock, don’t get hot, and they should last. My rear bulbs are red and they strobe when you hit the brakes. I had white LEDs before that and they weren’t close to the light these put out. If you can’t see these you’re either blind or dead. I kept trying different options until I found what I liked so I get that your committed to your project,
