1 - 3 of 3 Posts
Has anyone put Kuryakin brake and clutch levers on their 1500 Classics? I tried swapping-out my old ratty mis-matched levers with the Kuryakin ones listed for the 1500 Classic. I started with the brake lever and while the configuration was spot-on, the fit was so tight that when you squeezed on the lever, it would not return. It had nothing to do with the screw tightness as I tried with and without the nut. I didn't even try the clutch one. What is everyone running on their 1500E? Thanks......Bill G
It was above freezing today So I decided to put on my new mirrors and the levers. I suspect you have some corrosion on the inside of the brake and clutch unit preventing your levers from returning.
I made a video showing it working on mine and where you may be having your problem.
https://youtu.be/4wrQy9mPu6A
1 - 3 of 3 Posts
