1 - 3 of 3 Posts
Looking for a set of extended cables for a 2008 VN 900. Doesn't have to be anything fancy. Anyone have a set they's like to get rid of? Thanks.
BOTM Winner, June 2015
Check Phat Performance Parts online. You can get all the extended cables and the extended brake line for around 225 if you go with black. All of the cables' prices below are for stock length stainless. You add $20 for any size over stock, but if you choose black, you take that $20 back off so price is the same as stock stainless.
The throtle push and pull cables are Barnett and are $100.76 for stock length in stainless.
The Clutch cable is also Barnett and is $69.26 for stock length stainless.
The extended brake line Galfer and is same price no matter if stock or extended for $54.95.
Total Price = $224.97
PPP ships all orders over $99 free according to their website.
Good luck!
Thanks! I'm going to try and re-route (I installed 2" risers, and the cable are verrrrrry tight). If this doesn't work, I will check out the items you mention. Thanks again.
1 - 3 of 3 Posts
