1 - 10 of 10 Posts
HEy guys
I used spark tester and it is indicating that Im only getting intermittent spark on the right side of both cylinders. My first thought that it was a bad coil but schematics show that the coils are wired to the individual cylinders and not to the different sides.
What could be causing this problem? I have heard that this could be a bad pulser/pick up coil causing this but I want to confirm before dropping $100 on a new pulser.
1. How many miles on it?
2. How long have you owned?
3. What issues were you having that led you to test for spark?
1. 17000 miles
2. Owned it for around 10 years
3. It just stopped firing, was running ok with some carb issues but it just wouldn't start up the other day
No its not running now, it'll just keep turning over without firing.
Before this it was firing up, but anytime you gave it throttle it died. Figured it was a clogged pilot jet because it was running well before that started happening.
Discussion Starter #10
I never had a chance to fix it, it stopped firing when i came down to work on the stalling issue. I think that issue was because the bike was sitting for 6 months and there is some rust in the tank. I was gonna flush out the tank and clean the car when this issue happened.
1 - 10 of 10 Posts
