1 - 7 of 7 Posts
I'm trying to put on the integrated tail light from clear alternatives. good news the brake light and running light work. i need to know which wires to pull for the flashing unit to be installed. and also i've lost my front right blinker and the turn signal indicator light just stays on. if you think i'm wingin' it and i'm out of my league you're right. it's all fun and games till i get stuck.
Found this on there website.Just did mine at the shop that works on my car and it works on my 900LT , http://www.clearalternatives.com/flasher.htm
i don't have matching wires colors with those instructions. i can't even find a box that looks to have a similar input pattern so that i can at least make an educated guess.
I looked at my 2007 vn900 and mine looks a bit different as well. I did find a switch but looks different and has one little square emty with no wire. I hope that's the one?
I put a clear alternative integrated tail light on my 2008 Vulcan custom and took the front blinkers off (I unplugged them in the head light). Now my left blinker works and my right blinker doesn't the indicator light does not come on either any ideas
1 - 7 of 7 Posts
