1 - 5 of 5 Posts
Received my Galfer S.S tri-front brake line and noticed that there were 9 copper washers for the 3 fittings
Manual and what my OEM set-up had when I dismantled it only had 1 washer on
either side of the banjo bolt.
Am I to use 2 instead of 1 on certian sides ?
Did they just ship out extra ones ?
Not much more in life offered extra any longer. Thats what threw me off.
I would say yes they are extra :) I know it is hard to believe they would send you extras in this day and time. LOL! Most of the time now days you get shorted. :D
You use two on each caliper mounting point, that is four for that. I assume this is a kit with lines that run continually all the way to the master cylinder and connect with a new, longer banjo bolt to hold both lines, one on top of the other. That would require 3 washers. That totals 7. You'd have two extra.
The galfer set-up is the same as stock.
One line from master down to a T and out to the calipers.
So its a total of 6 with 3 bonus ones.
All is good now.
1 - 5 of 5 Posts
