1 - 16 of 16 Posts
Hey there,
I am in the process of de-winterizing the 2004 Mean Streak, and I had a hiccup: plugged-in the battery, checked connections, switched accessories on and heard that typical whirring sound of the gas pump, and when I pressed the ignition button, it just went "Click" and everything shut off. No lights, nothing.
I suspect a short in the ignition circuit. I checked fuses and everything seems fine (no burned fuse), I had to disconnect the battery and reconnected it, and then re-switched everything on (again with the sound of the gas pump) and again, when I press the ignition, everything just shuts off.
My next step is to re-wire the whole thing, but I am pretty sure there are some intermediary steps that I don't know of (and would allow me to enjoy riding season!). Which would be the first one?
Just so you know about the bike:
2004 Mean Streak
about 40,000 km
no mechanical mods
when I bought it there was a trailer ball, but I did not touch the electrical harness that was with it.
FTW2017, where is this yellow-gray wire? Close to battery or close to ignition key, or switch?
Sfair, I will check it but the battery was fresh off the charger. If that doesn't seem the issue, what would be the next step?
Thanks for your help gents,
Do not bother with yellow/grey wire. It is not your problem.
Fresh off of the charger means nothing to a bad battery.
Let us know how the test goes.
Ok
So I tested the battery that's sitting in the bike for 3days. It reads 3volts (I guess you're right that it's dead).
Out of curiosity, I also tested the battery that'll be going into the Suzuki M50: it read 13.9volts on the first reading, and then dropped to 12.8volts after 2 or 3 minutes.
I am wondering: should I keep the batteries on trickle charge when the bike are winterized? I have been taking the batteries inside, but not connected.
I just re-read the voltage on that second battery, and it seems to drop .5volt every hour.
Should I assume it's bad as well?
Ok
. Always, use a tender.
1. You need to charge battery and we can give it a quick and dirty test.
2. One thing bad about leaving a battery constantly on a tender is sometimes it can cover up a weak battery. A battery should be able to sit for at least a few weeks with no ill effects. If it is always on a tender, one starts their bike at home, no issues, but rides away somewhere where the bike has to sit for a while and then come out to a no start. I would rather find this out at home than 100 miles away from home.
Discussion Starter #10
ok, the battery is on the charge.
Can you be more specific to the test you'd want me to run?
On inspection, the battery appears good to go: no leaks, no deformation.
Initial voltage will be done (as with my second battery), and expect I will run a load test? Is there anything else (or more simple)?
Discussion Starter #12
So my multimeter is a Motorcraft 052-0060-2.
What should I look for, at what settings?
OK:
1. Take voltage reading across battery.
2. Turn on key and take another reading.
3. Leave key on for a full 5 minutes and then take another reading, key on.
4. Turn key off, wait 5 minutes and then take another reading.
Post back with 4 readings.
Discussion Starter #16
Hey Sfair,
sorry I got long to get back to you, busy week.
Here are the readings:
12.9volts (nothing connected);
11.88volts as I turn the key;
11.87volts after 5min with key on (then turned key off);
12.23volts at 5min after key turned off.
1 - 16 of 16 Posts
