I noticed that I have to put the bike in neutral to start the bike. Even if I pull in the clutch it will not start. This sucks if you happen to snub it at an intersection or a tight turn around. Has this happened to any one else? If so, solution?
The only time I need mine in neutral to start is when the kick stand is down, otherwise... no problemo!!!
Kick stand was up. snubbed it on a very tight turn around and I had to put it in neutral to start the bike even with the clutch pulled in. I took it to the shop and they could not find out what the problem was. Just thought I would throw it out there before I take it back in.
Couldn't be the kickstand safety switch, or ya wouldn't be able to keep it running when you put it in gear... Hrrrm... I know my '08 Custom will start with the bike in gear, so long as the stand is up and the clutch is in, so that sounds odd.
My wife's 900 had the same problem after we added risers to her bars. I re-routed some of the cables and lines to give them some slack, but the wire harness to the left side handlebars seemed alright so I left it alone. It ended up puling loose a connector just under the middle of the gas tank. There's a set of connector blocks under there that parts of the wiring harness run to. I ended up just unbolting the tank and sliding it up and back just enough to get at those connectors. Plugged the two wire connector back in and all was fine.
