That would be a lot of space here and I don't really have the keyboard shortcuts for symbology. --|/|--|(--|M|--
The same thing for the resistor in the key switch. That resistor could have just as easily been put into the IC Igniter safety circuit. The Honda Common Service Manual has a pretty informative descriptor on the SCR controlled safety circuit for the ignition when used with sidestand cutout circuits.
Otherwise the fuel pump ground circuit comes through the ECU (pin 37 on the VN16 Nomad). No ground, No pump. The positive on the W/R wire comes from DFI main relay through the DFI main fuse. The same for the injectors and coils. W/R ready at key on and waiting for signal to complete the ground.
Come to think of it, I had a similar discussion way back and someone was trying to say the the ECU cutoff the DFI relay to shut off the coils and injectors when the T.O. sensor was active. I explained that wasn't possible since the T.O. sensor is powered by the DFI relay.
Is that better?
