The horns are Hella Supertones, here is a link and specs. It shows 5.5A per horn, if I use just one I should be ok right? I believe the OE fuse is 10A... (thanks for the help electric confuses me)
http://cat.hella.com/hella-nafta/upload/USAData/2009_Horns_information_flyer_mounting_instructions.pdf
Looks like these are big on current. Spec says they are 6.5A each. Use one you are ok. If you are using two then you will have to use a relay rated for the higher current. Use your horn button to activate the relay and run a separate bigger wire from battery to the horns through the relay. I would also use an in-line fuse to be safe, maybe 15A.
part number 3AF 003 399-051
Materialtext HORN S-TONE 12V 500HZ HTONE
Catalogue Section Electric
Nominal Voltage [V] 12V
Wattage [W] 78
Frequency [Hz] 500
Sound Level [Db (A)] 116
Torque of Bracket [Nm] 10 - 15
Weight [Kg] 0.59
Amperage [A] 6.5
Housing Black Coated Metal
Black Protective Grille
Feature 83 mm Bracket
Brand Name Hella
Package Quantity 1
Country Of Origin DE
UPC code 760687056713
Package - Length [In.] 5.62991
Package - Height [In.] 4.92125
Package - Width [In.] 3.74015
Package - Weight [Lbs.] 1.300714
Product Description (long) Supertone High-Tone, 12 V, 500 Hz with Bracket
UPC Code 760687056713
Thanks!Sorry FIAMM makes some that look almost the same.
Yes use one horn and you are good. I use the low tone. You can use the relay to supply two horns which will raise the dB level a little, use one low tone and one high tone and it really gets noticed.
Still not as loud as an air horn. But sounds good and gets attention.
hey truckie,
I replaced the horn on my v2k with two louder electric horns and installed a relay, it keeps the bike wireing from being over loaded and protects your switches, it supplies direct power from the battery to the horns and you are able to run two horns with no problems, but you must install a fuse at the battery connection, the bottom line is you are adding safety to the horn circuit
good luck
Does anyone want to do a "how to" on the relay for people like me who are non electrically inclined? Thanks in advance.
Thanks! What horns did you go with? Where did you mount them? Does two horns require two relays?
truckie
these are the horns i got from harbor freight for about 8.00
and the link for the installation instuction
you can use the factory switch that is on the bike
http://manuals.harborfreight.com/manuals/99000-99999/99911.pdf
