Hi SY;
If you are not so sure you made the right choice because of high speed highway revs then maybe the new gears will do the trick, but could be you want a V1700. Regardless of the choice, if you have a vibration at high speed you should bring it back and get it fixed. Might be as simple as tire balance. When that's taken care of then decide if you want to keep it.
WEG
WEG
