1 - 15 of 15 Posts
  • I have a 2011 1700 it has a ticking noise I’ve had it to the dealer they replaced the lifters it went away but it’s back it seems to do it after riding for a while I’m wondering if I put 20/50 synthetic in it will help but I don’t want to void my warranty
I have a 2012 Nomad and the engine is noisy. A little ticking won't hurt the motor but if it is loud enough it is irritating. I always run synthetic in mine also and it really helps with engine noise and the shifting.
That’s what I’m going to do I had it to the dealer they replaced the lifters in the rear cylinder it stopped for a little while but it’s back they can’t figure it out either
You don't show where you live, but 20W-50 is only necessary if you are in a hotter climate area, and would probably actually make the ticking worse, if you are not. 20W-50 will not void your warranty, as long as it is compatible with a wet clutch. The 1700 manuals list it for use in higher temp climes. I use 10W-40 for winter riding and 20W-50 for summer, here in Georgia.
I’m in Knoxville
Knoxville has similar, but a little lower average temps to Atlanta, so 20W-50 might be the oil of choice for summer riding. If you only ride when the temps are above 65°F, then you might want to use it. If you only change the oil about once a year and you ride with it gets cooler, I would not recommend it, though. I definitely would not run 20W-50 if you would ride a lot when the temps drop into the 40s or lower.
I change the oil at 4000 miles. Long days cruising on the highway, like on a cross country trip are actually easier on oil (the industry definition of "normal"), so I will push it to 4500 miles then. In addition to Southern heat, I ride a lot in the mountains, a lot of stop and go city riding, and a lot of short rides, all of which are considered "extreme" riding conditions. Most years, I ride enough that it is not an inconvenience to change it twice a year to match the season. I just make sure that I have the right oil in it for the current temps.
Discussion Starter #10
I’m thinking just to go full synthetic 10/40 maybe it will help some I don’t know it’s just an annoying tick I’ll just ride till it flys apart sometimes the tick is loud sometimes you can’t hear it I guess it’s just the nature of the 1700 beast
I agree with Sabre-T. Run 10/40 in the winter and change over to 20/50 in the summer. I ride all year here in southern NC and if it ends up being a cold winter I will run Rotella for a few months then switch back before it turns hot. But either way, synthetic does make my Nomad sound and run smoother.
I've always found that the best answer to all those worrying little ticking & clacking sounds - is a pair of good quality molded ear plugs. (y)
My '13 1700 has a slight tick at times. Usually, after warming up good for a few minutes and holding it up (off the kick-stand) the tick goes away. I think it's pretty common for this engine. I've asked a couple of knowledgeable mechanics about it and the response is always "just ride it".
2006 Vulcan Classic 1500 fi / 2009 Vulcan Classic LT / 2010 VOYAGER ABS
I have a 2009 1700 LT and I tried to run Rotella T6 full synthetic in it (10/40) and it did not like it, it made a lot of noise so I changed it out and put Quicksilver 10/40 and it quieted up right now. I also have a voyager 1700 and it has no problem with the Rotella
go figure
1 - 15 of 15 Posts
