1 - 5 of 5 Posts
Yup, it's a key lock. You might want to put some slight pressure on the back of the seat to help it release.
Added note.Press down hard around the middle of the passenger seat and turn key clockwise.I suggest u grease the mechanism .There is a cable that runs from this to the key/lock.If it is very hard to turn the key dont force it ( the key will be damaged).Also if u have a strap running from one saddle bag to the other under the seat that creates undue pressure ,if it can unzip pull it out from rear.
1 - 5 of 5 Posts
