1 - 3 of 3 Posts
I have a 2006 vulcan classic and it is hard to start. The battery will turn the starter over, but it will not start. does it have an electric fuel pump and the battery is not strong enough charge?
Hi there
Please control at first the fuses behind the left side cover. Maybe a fuse blow up. First idea what i got.
I bet it's bad gas!!! That's a huge problem now... Only use 91 and if u can only use chevron gas, u should use a injector cleaner in what gas u have now then get the good gas from chevron. I had the same problem that's how I know, u said bike cranks but wont start sounds like not getting gas to fire over.
1 - 3 of 3 Posts
