1 - 20 of 27 Posts
Ok ay started oil change. Drain oil...no problem. Now can't get oil filler cap off to refill. I do not have the "special" tool.
Does it screw on?...snap on?
Any suggestions be grateful!
Frank
okay...that's what i thought but it doesn't move at all....need to go eat some spinach i think.
I ordered a replacement crome cap from ebay. The stock filler cap takes a special slotted tool. I used a pipe wrench and threw away the old cap. I think the cost was around $25 with shipping. By the way turn the cap to the left counter clockwise.
Found a open ended wrench from my sons scooter tool kit. Was perfect width. Came right off. Thanks for help.
Frank
Try the end of the shock spanner in the toolkit - the part you slide the handle on. I have also used a money clip - does not leave a scar on the plastic cap...... (twist it with a pair of pliers)
I'm sorry I misspoke. I purchased the chrome filler cap for 8.95 plus shipping. The problem was what you are having a gorilla at the dealership put the stock cap on. I attempted some of the above. The new cap looks much better.
Someone had robbed the toolkit outta the bike by the time I got it, so no spanner. Had to improvise. A 50c piece fits perfectly and if a little tight a small cresent wrench across Kennedy will do the job.
I think another type of cap is a much better option.
I picked up a long gasket scraper at Harbor Freight for $2.98. A little grinding and I had a perfect fit tool for removing the fill plug.
I'm always amazed with this forum. It seems whenever I have a question, someone always asks it first before i can. This has happened several times to me. Anyway, I was wanting to do my first oil change and thought I would try to get the cap off before getting started. Yeap, same problem. I could not budge the cap and was ready to post a "how do ya" thread on the forum. Glad someone already beat me to it. :) Good info. I was nervous about scratching up the cap getting it loose. Good to know if I booger it up, a replacement won't cost me an arm and a leg. Thanks all.
+1
I got a piece of metal close to the thickness of the slot and ground it to size. Held the metal bit with some vicegrips and voila!
The Hulk must have owned my bike before me, I had to use an Estwing pry bar with a 90degree bend in it. It fit the slot perfect, no marring....worked like a charm.
They sell alternative ones on Ebay all day. I originally bought one that said Vulcan on it. Vulcan was upside down though AND it wasn't the easiest thing to unscrew so I bought one with a single tang on the top which is always easy to take off and doesn't look like it's upside down.
I put a flat tip screwdriver in mine, and put some vise grips on the screwdriver and turned it broke loose and came off easy, remember counter clockwise, good luck hope this helps.
Great idea!
If you cannot locate a large washer to fit the slot turn the bike upside down and fill via the drain hole.
Im glad i wasn't the only one thinking of doing this, it will work but make sure you drain the gas from the fuel tank,and remove the backrest,and use a blanket to keep your grips and levers from being scuffed up. plus the sight glass is much eaiser to see.
1 - 20 of 27 Posts
