1 - 11 of 11 Posts
VN900 Classic 2007 - 11481 miles.
After all works with manual the second cylinder is knocking. Warm or hot it's the same.
What to do?
I would start by removing the valve covers and checking from there. It sounds like a valve train issue. It's interesting that it still seems to idle ok. Did a valve shim come out, causing the knocking noise?
Don't think so. We checked many times and do everything with the manual, but it's still knocking
Ok. My next thought was be maybe a loose wrist pin, or piston slap. But it doesn't exactly sound like either of those. The next thing I noticed was that the knock sound is much sharper on the right side than on the left. That leads me to believe there could be a burned exhaust valve on the right side (of the 4 valve head). Can you do a compression test on both cylinders, and report back with your findings?
ok, i'll ask about it! thanx a lot, bro
The problem was that the second cylinder was not working. This is done.
Ride, washed. In the morning they started the motorcycle, it started to get hot and stalled. Twists, but won't start
Discussion Starter #9 (Edited by Moderator)
Exactly. They said that the second cylinder was not working cuz of spark plug. Cleaned the spark plug and he started without knocking. When i came to take him back. He worked for 1-2 minutes and stalled. Tired of this crap. Whole summer i just waiting and waiting.
I;m glad you found the issue and I'm glad that's all it was. The vulcan 900 has a pretty robust engine, glad to see all is ok with your bike.
1 - 11 of 11 Posts
