1 - 4 of 4 Posts
I was thinking of installing a bar snake. I pulled one of the end caps off (iso grips) and there is a plug about 1/2" inside.
Are these bars solid?
the plug you see does 2 things .. 1) provides the treaded hole for the OEM grip to screw into ... and ... 2) provide some vibration dampening
should be no issue on removing it if you are putting the snake in //
Let us know if the snake works ..
Thanks, I just looked through the hole in the end of my grip once i removed the end cap.
What holds that insert in?
1 - 4 of 4 Posts
