1 - 4 of 4 Posts
stupid question... I took the headlight assembly apart, but I didn't notice how that little bracket that holds the bulb in place is secured, and now I can't figure it out! Any help? Pictures available? Thanks
not sure if this pic from the service manual helps :(
Lay the headlight on a soft cloth on a secure table or bench.
Its a little spring - you need to push it down (towards the front glass of the headlight) by the part of the spring that is sticking out towards you - and kinda around the little hook doo-dad that its secured in.
It then swivels out (like a door hinge) and releases the bulb. This is a "normal" spring device used on many headlamp systems.
1 - 4 of 4 Posts
