1 - 4 of 4 Posts
Hi there, I have noticed recently that the gear box on my 2008 vn900 custom is hard to shift at a cold engine, also when the gear is between 2-3 gear & at a low speed there is bit of vibration from the engine, and after the engine gets hot everything goes back to normal, I have a doubts about the cluch plates, but I need an advise before changing it.
What do you mean with "the gear is between 2-3 gear "? False neutral? If so, I wouldn't care too much. You are not supposed to leave it between gears. Shift technique could explain the vibrations (slow shifting while not matching speed of transmission input and output shafts).
What oil are you using?? where do you live - colder weather time?? Sounds like a problem between the seat and the Handlebars!!!
1 - 4 of 4 Posts
