1 - 9 of 9 Posts
Hi all,
I got a 2015 vulcan s 2 weeks ago. Ive only been out on one ride so far and found it really annoying not knowing what gear I'm in. I know there are both genuine and after market options but im wondering if anyone knows if a 2017 onwards speedo would work on a 15.... Given it has the gear indication on it?
Cheers
2017 Kawasaki Vulcan S 650 ABS
I can't say it will or won't, but I can't imagine it would without the wiring needed, which I would not expect them to have in a version that it was an after thought. I have a 2017 and I'm still getting the OEM GPI because the LCD is too low when using a full face helmet for me.
Cool thanks for the replies. So you all are going to oem or is there a good aftermarket option. The after market ones I've seen are cheap but look alright. But the way they work seems sketchy and I dont know if they would suit me.
I bought a cheap one off Amazon that plugs into the diagnostic port of the ECM. Has worked fine for a couple of years.
I bought one from amazon, for my 2015 that was relatively cheap, that worked perfect and was bright. Also worked off the Diagnostic port, under the side cover. Plug and play!
2015 - Kawasaki Vulcan 650s
i got the cheap $40 off amazon also has a few second delay and doesn't recognize the gear when the clutch is in but very easy to install and comes in different options of color design & shapes, but for $40 it was well worth it instead of paying the hundred plus for an OEM one, took 15 minutes to install. you can see it in use here
Nice quick shift. So I learned for those with 2017+ the OEM GPI does not plug in play, requires splicing I didn't want to do.
1 - 9 of 9 Posts
