1 - 2 of 2 Posts
I've had a small oil leak on a 98 800 classic vin b that has been getting progressively worse and I'm out of cardboard so im going to attempt to actually fix it. I get a line of oil leaking from the lower valve cover that runs right over the casing and to the ground but the oil is always fresh and never black. It appears to me that I have a valve cover gasket, a second gasket at about mid cylinder and then is there a third gasket at the bottom right before the crankcase? I'm guessing I need to replace the two lower gaskets but am having trouble with the vernacular for them. Can someone tell me the name or give me a part number.
1 - 2 of 2 Posts
