1 - 5 of 5 Posts
I have a 1994 Vulcan 750 and after changeing the gastank this winter i can't get gas to feed. I can put starter fluid straght into the carbs and it will start but then quits. I know that it sounds like i turned off the gas but that's not it.
Anybody got good ideas?
Pull the fuel line off that goes to the carbs, at the carbs, put the end in a pop bottle, turn the fuel tap to prime and see what comes out, if anything.
Why did you change the tank?
Post back.
thanks for the thought. I will try that over the weekend.
The old tank leaked when i bought it.
Post back.
Got it working,,, thanks for the Tip. The only problem i have now is that it won't idle.
I know this is a old post but if you ever have ideling or running problems again try a can of SEAFOAM in the gas tank....works wonders and is cheap.
1 - 5 of 5 Posts
